Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Any pictures?yes o-rings under the weight & roller bolt and nut will quiet the clutch.
sk-rx1
Yes, I did the nylon washers from SB on my Viper. Very little improvement. A little reluctant to do the loctite thing, it seems at least some would wind up in the engine.Yes, I have lived with the loud clutch, and it performs well-much worse on one then the others. The stub shaft seems to be the source as those who 'locked it down' with special forms of Loctite stated it ALL went away on the Vectors. While those who used nylon or silicone washers saw only slight improvement and short lived if I recall correctly.
Lots of posts about 1-2 year ago.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
I had very little rattle from the Apex , but my Viper annoyed the hell out of me , I hope the SW isnt as bad , I couldnt stand the noise
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
From what I understand it will be about the same.I had very little rattle from the Apex , but my Viper annoyed the hell out of me , I hope the SW isnt as bad , I couldnt stand the noise
A lot of people seem to be complaining about the noise. The noise is characteristic of the clutch design in combination with the three cylinder motor. The noise is a small price to pay for a clutch that works really well. It might be a different story if the clutch didn't work as well as it does and still made a lot of noise as well.
I have an Apex and it is very quiet as far a the clutch noise goes. The droning noise on the other hand while riding the Apex is another story. Don't seem to get that droning from the viper.
sk-rx1
X2I had very little rattle from the Apex , but my Viper annoyed the hell out of me , I hope the SW isnt as bad , I couldnt stand the noise
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Understood I have a 2010 Vector I just HATE to hear Idle.......I mean sounds like a bucket of bolts shaking. under way quiet smooth and the family favorite.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the solution is either to change the weight to a weight thats pressed against the roller...or possibly to shim the spider to creat the weight to roller contact..or...a larger roller which wouldnt be advisable since it would make the weight act lighter..
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
So a noisy Sidewinder clutch at idle is more of a norm than a rarity?
Any other SWs experiencing this?
I have approx 100 miles and mine started today...Rattles/clicks at idle...bit of a PITA...
bleedyamaha
- Sep 28, 2013
- Northern Iowa
It's the rattle snake that killed the Viper in there. Mine is alive and loud as well
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
I notice more on my Sidewinder than my Viper because Sidewinder is so quiet
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Lol. Funny you mentioned that. I had a Doo guy point it out on the lake today. He said "WTF is that sound...", I said, not sure but I "doo" know that I blew your doors off 5 mins ago..." lol.
I'll go with the "rattle of the snake".
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The rollers/bolts are going to rattle on these clutches. Also weights are not tight to rollers. Mine are way off rollers.. BUT all this means nothing because the clutches just flat out work and run cool!
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
It's either the rattle snake set on kill or the cat trying to claw it's way out
krm
- Apr 22, 2016
- ny
sounds like buck wheat shooting dice .
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
not perfect...but mine is much quieter now...thanks to the o rings..
