Studroes144
- Oct 30, 2013
I have an aftermarket helix how would you be able to tell them how much to cut out where the spring sets1/8"?
More than likely already done if it's an aftermarket helix.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Well today was 40 degrees out and we did some groomed trail riding across open fields and no wind. I switched to a brand new 8dn belt today. After several miles of riding my rpms stayed consistent holding around 9150 and speeds varied from 85 to 90 tops at WOT. Far cry from 106mph on hard packed roads. I am guessing with my gear change I lost a little pull in there. 40'degree outside air temp and intake air was 90 today. When I did speed runs on road outside temps were 20 degrees so with that I do believe cold air makes hp.!
And soft snow has a lot of drag.
83-84 today for me. Warm temps and ECT. Wet and packy snow. Big stiff lugs holding me back.
Sad part is the 90HP Skidoo went just as fast in same conditions spinning a 137" 1.6 Ice cobra and running 3-400 rpm below target.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Today I rode on a river that had and inch or to of snow and was easy to spin out. Made several runs and after packing it down I did see 88" before having to slow down. A 2007 Phazer was seeing 78 in the same area. No comparison though.
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
106 on road not realistic trail conditions see post on viper Rtx- LE.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Ya I know its not realistic conditions as the post says n/a top speeds. I was just comparing to different runs under to different conditions. Today was real conditions other than 40 degree temps. Doesn't the rtx have 8 tooth driver?106 on road not realistic trail conditions see post on viper Rtx- LE.
Curtis Chambers
- Nov 19, 2014
I believe from other posts last year from other guys it is 8 tooth. I Was saying I saw 106 on road not realistic trail conditions.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Was that on his speedo, or riding next to you?
Same rider (me) same stretch of trail minutes apart, and same GPS.
Studroes144
- Oct 30, 2013
Cat 7000, clutch kit and air box mod. Perfect hard packed plowed road it'll do 99, tonight on the trail with slushy snow and 43 degree temps it struggled to break 80. Seen 80 a few times and 83 once. Conditions are everything as all the sleds I rode with today complained of slow speeds, except the cat turbo, he could cruise at 90 on the same trails I struggled to get 80 lol.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
That's good to compare to mine yesterday. Did you see your air intake temps by chance?Cat 7000, clutch kit and air box mod. Perfect hard packed plowed road it'll do 99, tonight on the trail with slushy snow and 43 degree temps it struggled to break 80. Seen 80 a few times and 83 once. Conditions are everything as all the sleds I rode with today complained of slow speeds, except the cat turbo, he could cruise at 90 on the same trails I struggled to get 80 lol.
Studroes144
- Oct 30, 2013
No, never thought to check, engine temp stayed at 167 the whole time.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hey Studroes If you don't mind me asking what clutch kit do you have on your 7000? I thinking of doing the airbox on wife's 7000! She has the sandales pipe on it already rpm's are right at 9100 but with the airbox mod I think she may be into her rev limiterCat 7000, clutch kit and air box mod. Perfect hard packed plowed road it'll do 99, tonight on the trail with slushy snow and 43 degree temps it struggled to break 80. Seen 80 a few times and 83 once. Conditions are everything as all the sleds I rode with today complained of slow speeds, except the cat turbo, he could cruise at 90 on the same trails I struggled to get 80 lol.
thanks
Marc
Studroes144
- Oct 30, 2013
thanks
Marc
I'll pm you the setup
