Nosiy Primary clutch
BlueStroke
Trumbull,CT
I'm a Newbie to the site and from what I see so far its Great to be here! I have a Apex Gt 07 and I was changing the oil and running it on the stand to check the oil level. While running I notice the primary clutch weights were really rattling and when I engage the clutch you hear the sheaves slapping in and out. Ever since got sled I always I thought it was loud but seem to be worst now. I inspected the clutch and don't see anything wrong or worn.Is this normal and I was thinking of installing a aftermarket kit for trails any suggestions.
Some noise is normal...just bring up your IDLE to 1500 rpm's +/- and noise usualy disapates, make sure to keep it clean by blowing compressed air to get all debris out and DO NOT use lubricants keep it CLEAN 'n DRY, I had 12.000kms on my '05 RX1 and still within spec...there's also a little bit of noise coming from the gear reduction right behind your clutch, again NORMAL.
WELCOME aboard :-o
BlueStroke - like apltx08 says, it's normal to have some noise from the clutches at idle and also when the sheaves engages and disengages.
PS! Please add your location in your profile, site rules :)
