Bill Hooper
- Jul 20, 2016
- Michigan
- 2012 Polaris IQ Turbo
2009 Polaris IQ Turbo 2up
2000 Polaris XCR 800
Hello,
I have two 2017 Sidewinders. One is an LTX and the other an STX. There is no difference between them as I swapped the track out on the STX for the same one I have on the LTX, which is a 1.25" Ripsaw 2 with studs. Both have the same gearing, both have had the primary and secondary clutches built with the same Thunder Products Clutching kit (weights, glide washers, springs) plus all new rollers in the primary and secondary's for both sleds. Sleds are identical as far as I can tell. Pressure tested the boost system to make sure there were no leaks. Tested to 15psi and both sleds lose 5 lbs in 10 seconds, approximately. Both have had the red fuel return line elbow drilled out to 5/32" to fix the fuel return issue.
Problem - Sled 1 hits 8800-8900 rpm at WOT, holds the RPM, but only hits about 100mph give or take a couple. Feels like it runs perfectly, just low top speed. Sled 2 hits 8700 but them immediately sinks back to about 8200 to 8300, but it hits 112 mph pretty consistently. Both were tested on the same section of trail, same conditions, at exactly the same time.
I am stumped. I have no idea why this is. My next step was going to be to install a boost gauge on both and see if both really are hitting ~10 psi and holding it. Both sleds feel perfectly good, HUGE acceleration, very smooth running, just one hits the RPM but not the speed and the other hits the speed but not the rpm.
Can anyone help me here?
Thanks!
Bill
Thanks!
Bill
Did you buy them new? Maybe one is tuned.
Same belts?
Same belts?
Bill Hooper
- Jul 20, 2016
- Michigan
I've owned them since 2018 and 2019. Both have exactly the same belts. Neither is tuned.
BIll
BIll
how many miles on each of them?
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Did you reach out to thunder. They're good guys they'll help you.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
My 17 would do this also when stock.
Even with the stock clutching.
Mine would pull the 112 speed when rpms were at 8800 or at 8400.
Never figured out and exact reason for rpm drop other than high intake temps causing computer to back off rpms.
After switching out primary clutch and tune never seen rpm drop like that any more.
Intercooler plugged with snow and ice?
Have you verified each speedo with a gps speed app on your phone. Are the speed sensors properly secured to chaincase, they are known to come loose and fall off.
Bill Hooper
- Jul 20, 2016
- Michigan
Mr. Sled - Sled 1 that hits the rpm but not the speed has 11,000 miles. Sled 2 that hits the speed but not the rpm has 5,000 miles.how many miles on each of them?
Bill Hooper
- Jul 20, 2016
- Michigan
Both sleds were confirmed completely clear of snow and ice in the intercooler area.My 17 would do this also when stock.
Bill Hooper
- Jul 20, 2016
- Michigan
I have not verified via GPS. I could try to do that on the next ride. Speed sensor on both sleds appear to be attached.Have you verified each speedo with a gps speed app on your phone. Are the speed sensors properly secured to chaincase, they are known to come loose and fall off.
Bill
So one sled is tighter and one sled is loose, or one sled makes more HP then the other , if you adjusted the clutching so they they both run at the same RPM at WOT, you should see closer speeds.. just my thought.Mr. Sled - Sled 1 that hits the rpm but not the speed has 11,000 miles. Sled 2 that hits the speed but not the rpm has 5,000 miles.
Bill Hooper
- Jul 20, 2016
- Michigan
Mr. Sled - My goal was to the the sled that made the speed but not the RPM, was to get its RPM UP to where it should be thus increasing its speed. For the other sled that makes the rpm but NOT the speed, figure out why its so slow and bring its speed up equal to the other sled.So one sled is tighter and one sled is loose, or one sled makes more HP then the other , if you adjusted the clutching so they they both run at the same RPM at WOT, you should see closer speeds.. just my thought.
Bill
Bill
but is the faster sled running at the ideal RPM and the slower is over reving? loading it heaver would make it work hard to make speed if it has the HP to pull it.
Bill Hooper
- Jul 20, 2016
- Michigan
I did a pressure test on both sleds and found that if I pressure up to 15 lbs and stop, I lose 1 lb every 2 seconds, so I lose 5 lbs in 10 seconds. That doesn't seem like a lot to me ... am I wrong? Is losing 5 lbs in 10 seconds excessive? Seems like any loss is made up at the wastegate and so boost would stay the same.
Bill
Bill
Bill
That sounds excessive to me.. @Srxspec
- 24K
