audun34
- Aug 24, 2012
- Norway
- Nytro XTX
KMOD 153" skid
Skinz front end
Having trouble with too low idle when engine is hot. Drops down to 750-1000 rpm and can just die out.
Idles normal when cold.
Have checked throttle cable and tried to adjust both ways without any changes other then
activating TORS. Also tried changing CO settings, everything between -15 to 20 without any
big changes. Checked vacuumhoses for leaks etc.
And there are no error codes and new sparkplugs, and it runs normally as long as Im on the throttle.
I can add that Im running a CR racing tunnel dump exhaust and airfilter straight on the turbo it that can affect this.
Can someone point me in the right direction ?
Dr. FeeLGooD
I have a similar problem. Low idle speed when warm and stumbles a bit when I am working the deep when it is warm. Seems to get a little worse the longer I push it in the snow.
