SQUIRREL
Well here is my first go at it will see when snow flies. Didn't wnat to start out with a 200.00 plus muffler to find out it didn't work as planned, so I started with a 2001 can off of a R1 had t otrim it down quite a bit and also modify the baffles inside to flow right after cutting down. I have exactly 70.00 in it and if it doesnt work I can always go back to stock or order one just couldn't wait. Still need to mount the strap under the seat and trim down the aluminum under the seat to look good and then adding a sheet to close off the tunnel. Stock muffler and brackets and plastic 17 lbs titanium slip on from R1 cut down 6.6 lbs and sound isnt to bad try and post a clip. ok cant post a clip anyone want to here it and can help pm me
Jeremy
Jeremy
Pureadrenaline
- Apr 6, 2005
- SW Michigan
- www.myspace.com
looks good i was thinking the same thing, ill try and help post the clip if you want.
- Apr 14, 2003
- Hessel, Michigan
Looks good man, and I would like to know how it sounds also.
NB-NYTRO
thats gonna sound sick.. post up a clip.
SQUIRREL
here are some updated pics not sure if I like the plastic or not I amy stick it up in there a little further and just run a plate over the old opening. sne me an email at jeremy@jeremycampbellrealtor.com and I can forward the sound clip.
snownutz
With the tunnel blocked off I think it will look awesome.
lucky_7
I like it a lot better with the plastic. Looks almost stock! Good job!
Nikolai
I like the mod look without the plastic.
lucky_7
You are in New Mexico? How far is it for you to go ride?
SQUIRREL
like the mod look to but the seat reinforcement would take more work may do it dont know, hope I got everyone on the sound clip.
As far as how far to ride I can leave my driveway and the end of my road turns striaght into National forest elevation 8500 feet or I can go play in southern colorado in about an hour.
Fasttoys
wow that looks good! i would close off the tunnel as snownutz stated
