m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
radianguy
- Jan 1, 2007
Looking forward to seeing pics!
I got rid of rear sag with a set of 1900nm springs from ulmer racing. Stock springs were 1400nm I believe for 09, much better with the heavier springs.
m.schuey7
- Feb 4, 2014
m.schuey7
- Feb 4, 2014
No snow here yet, will post a ride review soon.........I hope
koreyahlers@hotmail.com
Nice work. Interested to see what your thougts are.
m.schuey7
- Feb 4, 2014
Thanks Korey,
Might be able to ride here in a couple weeks as the weather reports snow in the hills Sure feels good to just jump on it and and bounce it, much more responsive than the stock XTX shock and spring set-up.
m.schuey7
- Feb 4, 2014
Excellent, very excited to hear the results!
terez
Very cool setup!!
That's how Yammie should have built the XTX...or at least with conventional arms....the transfer rod skid was a poor go from day one...
So the SE parts bolt right up to the XTX rails....no drilling or fabing required? Other than swapping the MTX wheels ??
So if a guy was buying parts to do this to an XTX he would need the shock/relay rods and associated hardware/upper and lower scissor arms?
Did the new holes in the tunnel at the rear go in the existing reinforcement plates or need new plates?
So all the parts from a SE rear from the shock to the rails then...minus the upper wheels being reused from the XTX...correct??
Great setup!! thanks
Be very interested to hear how it performs.....
Transfer/ride etc.
I have a shorty that I have been hedging on extending and if so how to go about it...
Rail extensions, xtx skid swap, onother brand skid swap, Tamer skid etc.
This setup looks pretty cool, decently light, sturdy and sano.
And I would end up with a better approach angle and tipped rails.
Transfer/ride etc.
m.schuey7
- Feb 4, 2014
Terez,
Yes, Bought a 2011 MTX SE skid used and basically bolted it directly onto my XTX Rails, didn't drill one hole. Like you said I had to swap the top MTX wheels and find a lower mounting point for the rear mount of the rear suspension. Study the photos and you can see what I did there. The front Skid mount is in the stock tunnel hole, the rear one is reinforced and is part of the JRE re-locate kit. My ride height is almost identical, almost no sag now and 11 pound weight savings. Hopefully be able to ride it soon but think its going to keep the skis on the ground better and ride smoother in the bumps.
m.schuey7
- Feb 4, 2014
Finally rode the new skid last night in zero degree weather, groomed trails that were soft and rough.
For starters everytime you get off the sled its not sagging in the rear anymore, the rear rebounds back up to full ride height every time you step off the sled, even with the tunnel iced up. In the rough terrain corner "throttle on" exits the rear suspension stays smooth and planted, the more throttle the smoother over the bumps. Throttle on transfer seems a bit better than stock but hard to tell as I have a blower now and the sled is light on the skis during acceleration, doesn't seem excessive though.
The ride is definitely smoother all round. I purposely hit some rather large whoops while accelerating and wasn't able to bottom out the suspension although it did firm up progressively towards the bottom of the suspension stroke. Overall I'm glad I did it, improved the sleds ride and performance, most notably in the rough terrain while accelerating.
Garnotte
- Dec 24, 2014
- Nytro
That's weird, i'm planning to do the opposite, a xtx skid under a MTX because the mtx skid with the fox is the worst thing I ever ride in my life...lol I just send the fox for revalving yesterday, it's the last chance this sled have!
m.schuey7
- Feb 4, 2014
Garnotte,
Probably depends on how you ride and where you ride. I'm an aggressive trail rider. For these conditions it definitely works better than the Stock XTX skid suspension. Smoother ride and better "stiffer" dampening, the faster and bumpier the better it felt. The stock XTX would always bottom out in the rough fast stuff. And the sag was terrible especially when the tunnel was iced up.
If you want to purchase my XTX suspension send me a pm and make me an offer. Only has about 2500 miles on it.
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
I really like this I might have to do this. It's alot cheaper then going timbersled to shed weight
m.schuey7
- Feb 4, 2014
Yes, and the people I spoke to about the Timbersled sled skid all said that it wasn't suited for high performance trail use. (which it wasn't designed for so not surprised) I was also looking for a solution that didn't break the bank, saved weight (although not as much weight as Yamaha claimed....Surprise surprise) and was reliable. Everything has its pluses and minuses but this is definitely a good upgrade. The largest draw back with this generation XTX is the stock suspension, once you get it sorted the sled is very nice.
