fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
Fed up with the mickey mouse oil return pump on a powderlites set up, what does everyone suggest and wheres best place to get it? Sled is presently apart completely so I am open to all suggestions thanks.
fast n furious
- Jan 24, 2010
- Nova Scotia
MCX pump or maybe try new oiless comp turbo????
gunnerthesnowman
fast n furious said:MCX pump or maybe try new oiless comp turbo????
Yes i have seen some midmount set up with the MCX oil return pump.
What part of NS are you in ?
fast n furious
- Jan 24, 2010
- Nova Scotia
Halifax area, its a rear mount and uses a feul pump as a scavenge pump, on my third pump and there has to be a better way than this.
fast n furious
- Jan 24, 2010
- Nova Scotia
anybody have good suggestions?????
MCX pump. It's the easiest to install on works.
fast n furious
- Jan 24, 2010
- Nova Scotia
I guess the only suggestion is an MCX return pump? or has anybody tried a better electric return pump? I have installed smaller restrictor in oil line and made sure lines are not kinked etc as said in many other post's but this has been an issue from day one and while sled apart want to fix this problem once and for all. So where is the best place to get my hands on MCX pump, thanks.
Mountaintech
Prince George Yamaha.
TurboJamie
The FPP kits on doo use an oil sump / return pump. I had zero issues with it in 3000 km last winter its not a fuel pump and is very basic has no real moving parts to fail its an oscilating pump and just pulses a small metal piston up and down with a magnet.
I think this is it here http://www.go2marine.com/product.do?no=95746F
machzrobbie
Habich76
Turbo oil return pump option.
I used a belt driven Mechanical pump from Johnson High Tech Performance.
It required building a trick little bracket and a drive mandrel off the end of the crankshaft similar to a supercharger drive but it works flawlessly.
Here is a link to their site. Click the "rear end pumps" tab.
I used a 1 stage .400" (wide) gear pump because I bought it from a used Sprint Cup race car parts website for $80.00. I would assume a .250" gear pump would be sufficient for returning the relatively small amount of oil that we are pumping. I talked to Mr. Johnson about this and he said that he has folks using his rear end pumps for turbo oil return regularly.
http://johnsonsoilpumps.com/product_frame.htm
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Install a oil sump at the bottom of the turbo and a MCX Trochoid pump at the magneto/crankshaft. Make sure you use at least a 12mm oil return hose.
Do you have a restrictor on the oil feed line in front of the turbo?
hornydevil
Did you check the MPI system? The have a really good pump.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
hornydevil - welcome to TY
Please add your location to your user profile, it's a site requirement.
rxrider
TY Management Team
rxrider
TY Management Team
hornydevil
rxrider said:hornydevil - welcome to TY
rxrider
TY Management Team
Been here for a bit, just don't say much thats all.
