rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
How do those two springs differ RPM wise, both engagement and full shift?
rev them up
- Apr 3, 2006
With the grey spring comes in around 4300/4400...top rpm is around 9000...strong pull thruout.How do those two springs differ RPM wise, both engagement and full shift?
Dalton comes in around 4000/4100..top rpm is close to 9000...but seems like a slug in the midrange and top end mph is down a couple. I talked to a few ppl that also said they like the pull of the long springs...like to get a lower start rate ...just don't know who makes ling springs (clutch set up came in the sled when I bought it).
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
So it’s clear through Dalton’s testing that the grey/silver spring has considerably more rate than the black spring. In order to use a spring with that same rate and a low engagement you’ll have to lighten those weights up quite a bit, the compressed # will be quite a bit lower than either of those two springs. This also explains why you find the sled a little lazy in the mid range with that black spring......the lower rate makes the weights act more aggressive yet have a comparable full shift RPM because they end up very close in comparison when fully compressed in the clutch.
