Nytro Rtx hyfax removal help
donkickit
Upstate New York near Albany
2014 viper ltx se
So, 1100 miles hyfax are shot on my 2011 nytro Rtx. Took the screw off front of hyfax , pryed them back 6 inches or so and it looks like they are wider than my track window. Do u have to cut the window to get them out? Any tips appreciated.
Cut the window to get them to fit through. Get them off a bit and then start sled and put in reverse and it will pry it right off.
They"ll fit and the reverse method is the bomb!
There is no need to cut the track windows. Why cut on a track that doesn't need to be? Sounds crazy to me but if you want to cut it go ahead!
Use lots of silicone spray for removal and install. No need to cut the track. Its just a tight fit. Life lesson - tight hole, use more lube
I'm going to try loosening the track. 1 came off ok, the other not so much. Can't get it thru the track window. Reverse trick does work good once u gt it out the window.
No cutting........... Just lots of LUBE, oh yea and put some more LUBE on it it will work. :Rockon:
