LeeKo
I have heard a couple of guys talk about moving the stabilizer connection point at the lower a-arm. Mine came from the factory at the rear most hole. Is there anything in the manual that describes which hole is more aggressive? What is people’s experience with the adjustment?
LeeKo
LeeKo
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
No mention of the stabilizer bar positions in either the owners manual or the service manual.
I read here that a couple of guys here did it thus I tried it too. I guess it's likes putting in a stiffer swaybar on other models, it reduces the body roll and helps to keep the skis flatter in the corners, inside ski lift is reduced.
Very happy with this adjustment, I can attack the corners a lot better...try it, you'll like it.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
X2 - what Grimm said...I made the switch and it reduced body roll.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
although slight..it is a part of improving the whole package...
LeeKo
It is funny that the sway bar adjustment is mentioned in the tuning tips found in the Snowest article yet never addressed in the manuals.
Just to be sure...move it to the forward hole?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Yes, do it.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
LeeKo said:It is funny that the sway bar adjustment is mentioned in the tuning tips found in the Snowest article yet never addressed in the manuals.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what I did
unpride
can someone take a pic of this?
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
What would be the negative effect of making this change?
It's always a give and take isn't it?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
basically it seems to preload the bar vs waiting for the bar to catch later in body roll...obviously not the same as a thicker bar....but more proactive vs reactive...might increase the rate some as well
2008 Nytro RTX
Any pictures??
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Take a pic of your lower front arm where the stabilizer link bolts to it...then I'll circle it for ya.
scott32
- Jan 12, 2009
There is a front hole and a back hole located on your lower arm. For the stiffer position install into the front hole. The front hole is the one nearest the front of the sled. No need for pics as this is not difficult to explain or figure out. You need to do this to both sides. You are creating less hinge in the joint making it stiffer. Poor design really, but this is all we have to work with so far.
2008 Nytro RTX
Maybe it will be simpler when you go look at the sled
- 10K
