- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Here is a list of all the torque specs.
Here are the over view sheets:
Engine,Engine 2
Power Train,Power Train 2,Power Train 3
Chassis
Detailed images:
Chassis:
Body Panels,Body panels 2
Front Suspension FX10 FX10MTR FX10MTRA
Front Suspension FX10 FX10RT FX10RTR FX10RTRA
Steering (All the steering links)
Ski FX10MT FX10MTR FX10MTRA
Ski FX10 FX10RT FX10RTR FX10RTRA
Handlebars FX10 FX10MTR FX10MTRA
Handlebars FX10RT FX10RTR FX10RTRA
Power Train:
Primary Clutch Bolt
Primary Clutch Exploded
Secondary Clutch Bolt
Secondary Clutch Exploded
Chain Case WITHOUT Reverse
Chain Case WITH Reverse
Drive Shaft
Secondary Shaft
Brake Pad,Brake Pad 2
Brake Caliper and Parking Brake
Brake Master Cylinder
Slide Rail Suspension (FX10)
Slide Rail Suspension (FX10MT FX10MTR FX10MTRA)
Slide Rail Suspension (FX10RT FX10RTR FX10RTRA)
Slide Rail Suspension (FX10RTRZ)
Slide Rail Suspension (FX10RTRSZ)
Slide Rail Suspension (FX10XTZ)
Slide Rail Suspension (FX10M53SZ/FX10M62SZ)
Engine:
Seat and Fuel Tank
Exhaust Pipe and Muffler
Spark Plugs
Oil Tank
Oil Pump Exploded
Oil Pan and Pump
AC Magneto and Starter Clutch
Engine Mounts
Engine Assembly
Cylinder Head
Crankshaft and Balancer Shaft
Crankcase
Connecting Rods and Pistons
Camshafts
Cooling:
Radiator
Oil Cooler and Heat Exchanger
Thermostat
Water Pump
Water Pump Exploded
Fuel Injection:
Throttle Bodies
Air Filter
Electrical:
Starter Motor
If I have missed anything or something in incorrectly linked please let me know.
Engine,Engine 2
Chassis
Detailed images:
Chassis:
Power Train:
Primary Clutch Bolt
Drive Shaft
Secondary Shaft
Engine:
Seat and Fuel Tank
Spark Plugs
Oil Tank
Oil Pump Exploded
Oil Pan and Pump
Engine Mounts
Engine Assembly
Cylinder Head
Crankcase
Camshafts
Cooling:
Radiator
Thermostat
Water Pump
Water Pump Exploded
Fuel Injection:
Throttle Bodies
Air Filter
Electrical:
Starter Motor
- Nov 1, 2009
- 2009 Phazer RTX
Here you go guys!
apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
great links .. thks
- Nov 1, 2009
- 2009 Phazer RTX
No problem!
mach9
Just gotta say. This is really nice to have. No more searching through 100s of posts.
Thanks.
Thanks.
sprintcat
- Jan 13, 2009
- Rumford Rhode Island
- Nytro xtx
great
- Nov 1, 2009
- 2009 Phazer RTX
I am glad you guys are using it!
targabill
- Nov 10, 2023
- Yamaha Nytro
For the Cylinder Head Bolts it says TIP* But the TIP is not there?Here is a list of all the torque specs.
Engine,Engine 2
Chassis
Detailed images:
Chassis:
Power Train:
Primary Clutch Bolt
Drive Shaft
Secondary Shaft
Engine:
Seat and Fuel Tank
Spark Plugs
Oil Tank
Oil Pump Exploded
Oil Pan and Pump
Engine Mounts
Engine Assembly
Cylinder Head
Crankcase
Camshafts
Cooling:
Radiator
Thermostat
Water Pump
Water Pump Exploded
Fuel Injection:
Throttle Bodies
Air Filter
Electrical:
Starter Motor
- 7K
