- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Topgun said:Are your kits capable of more boost when nessary? Head shim also I presume?Srxspec said:I will have some vid and details about our kit after this weekends last ride before it gets switched over to the asphalt. This is setup and designed for the trail at 8 lbs of boost with instant throttle response, fuel and ignition mapping changes, etc. Details to come sometime next week.
Standard setup will be 8 lbs of boost on pump gas with no head shim. You will be able to push up to 12 lbs of boost but will need a good race fuel mix for that boost level.
jimmyhighway
- Feb 6, 2006
- Northwestern Ontario
- 13 Skidoo Freeride 137
11 Yamaha Nypex MCX
silversurfer said:jimmyhighway said:1900 miles trail / lake on the MCX kit. This set up is excellent!! Minimal lag, 85 - 105 miles of fuel range, 125mph radar. No issues other than ice build up on air intake.
Perhaps a dumb question given the pic in your avatar, but maybe that's another of your sleds.
The Nytro gets 125 radar? and 85-105 miles on a tank of gas? I might do exactly what Welter is doing in a couple of years, so I'm curious as well.
Yes the avatar is a little outdated. My Nytro RTX is extended to 136". I never had the chance to run it stock, but the current fuel range is great considering the small tank. It consistently runs 14mpg riding at the limits of the Nytro steering. lol
suburban
- Apr 19, 2003
- ontario
- 2021 SRX
BlueByYou2000 said:Id like to start a new project and thinking of a Nytro XTX and possibly a S/C or Turbo.
Thanks for your feedback.
I was thinking of this exact same project. The 144 should work good boosted..
Turbo595
- Dec 14, 2004
Turbo Connection Nytro
I would like to introduce the Turbo Connection Aerocharged Nytro.
No oil lines, no water lines, variable vane technology for quick rear/mid mount spool up.
I would like to thank Ulmer Racing for letting us use their Nytro for development and being our Number 1 dealer.
Topgun
Well Mr Ulmer, I'm thinking my Nytro should be the next sled for some fo your turbo development..............lets get it on!
- Sauk Prairie, WI
- www.ty4stroke.com
Re: Turbo Connection Nytro
More info and pictures please.
Turbo595 said:I would like to introduce the Turbo Connection Aerocharged Nytro.
same here more info.
- Apr 17, 2003
- Menno, SD
- Menno, SD
We will be releasing more information after this weekend. We'll post some pictures and video sometime Monday with some walk arounds and the components used in the setup. Hang tight until Monday please!
BlueByYou2000 said:Turbo595 said:I would like to introduce the Turbo Connection Aerocharged Nytro.
BOOST said:same here more info.
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
XTX - 8lbs boost - pump gas, but not a project - turn key ready to roll (east coast ready)
Sign me up
Sign me up
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Man I though Aerocharger went Belly up.
I had on on my Ski doo 670 Twin back in 98.
Cool.
Cool.
- Sauk Prairie, WI
- www.ty4stroke.com
millstreet said:XTX - 8lbs boost - pump gas, but not a project - turn key ready to roll (east coast ready)
Sign me up![]()
Me too!
Turbo595
- Dec 14, 2004
The orignal patent holders are building them in a new facility in Kansas City.
We can get them.
Brian
Ted Jannetty said:Turbo595 said:I would like to introduce the Turbo Connection Aerocharged Nytro.
Cool.
We can get them.
Brian
Hmmmm 66-Series would be nice for the high elevation guys...
Specs from one of their old product ads.
AEROCHARGER® Series 53000
Small to medium displacement applications.
Engine output range gasoline engines: 75 hp to 215 hp
Four (4) turbine and nine (9) compressor trims available.
Air Flow capacity: 136 CFM to 320 CFM
Charge Air Control: Diaphragm actuator, standard.
Pressure ratio: 2.0, for continuous operation at maximum rated engine speed.
AEROCHARGER® Series 66000
Medium to large displacement applications.
Engine output range gasoline engines: 120 hp to 350 hp
Three (3) turbine and four (4) compressor trims available.
Air Flow capacity: 214 CFM to 540 CFM
Compressor Maps -- Specs -- from the new Aerocharger 2.0 site
>>> http://www.aerocharger.com/sizing_the_turbo.htm <<<
- Sauk Prairie, WI
- www.ty4stroke.com
Allen, anything yet?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Sorry for the wait. A little hectic at the shop yesterday.
http://www.ulmerracing.com/FXNytroTurbo2.wmv
or
http://www.youtube.com/watch?v=iYJLSnzxMMw
or
- 7K
