The nytro will start right up when cold,will idle fine for a few minute,after a few minute it will start to missfire,If i touch the throttle it will either rev fine or stall.After arround 5minute of driving it wont idle at all and if i keep driving it for about 20minute backfire are alot worse and i wont be able to start it back until i wait arround 30minute to let the sled cool down.i've changed the 3 ignition coils with brand new one,new plug,new gas,new gas filter,bypassed tors.When it wont start and i keep cranking the engine for like 20-30 sec i have a fuel smell from the exaust.
Compression test was 205psi-210psi-215psi.Fuel pump is working,the only code im getting is 81 and 81 is for the grip warmer,tps show 16-96 on diag mode.Sled has also 33,720 killometer(21k miles)
I bough it in summer and i've only seen it running for like 30 second,seemed like it was running fine,but it wasnt the case,i couldnt test drive it back there was no snow and snowmobile are cheaper in the summer.Paid 3200$ cad for it i've been trying to fix it for the past 3month and i cant figure it out.I would appreciate some help from here thanks you
