Nytro won't start in the morning.
mcamzr
Armada MI
Need a little help confirming the issue here. Yesterday I went to start the nytro and ingot just a click from the oil tank side (relay I think) it wan about 22f outside. I hit the key a few times and it fired right up and no issues for the rest of the day. Today, a lot colder and sitting over night I get the same thing but it won't start. Is it a bad relay if I can here it click? Thanks for the help.
my brothers sled did the same thing
He bought a new starter relay ( I think it was 30 bucks) and the problem was fixed
you can by pass the relay, but can't remember how to do it
Take a test Light and see if you have power on the starter side of the relay !
You could also take a hair drier to the relay is it starts after it's warm then it's the relay !
That's it no power with the test light and 5 seconds with a heat gun and it fires right up. I think it's my fault though. I installed some mod rod A arm vents last year to help cooling before I put on the tunnel cooler and the vent is right I front of the relay just blasting it with snow dust and cold air.
Yes it is. Trading my bad one with the dealer Tuesday
