09Nytro_XTX
Going to be installing the OFT relocator this weekend, and was looking through the instructions from OFTs website. Step 9 looks to be the only 'tricky' part. do you cut away the upper bearing retainer assembly and NOT use it again? Anyone care to explain what you did, or what to do?
shadow44
I cut mine off
Stoli
I think you are talking about a little metal hook to hold the wiring.
You can remove it... it has to be removed or it will hit the relocator.
09Nytro_XTX
You can cut it off, and do not need to re-use it because it is replaced with a new oft part, correct?
09Nytro_XTX
Stoli said:I think you are talking about a little metal hook to hold the wiring.
Yes the hook is what i am talking about. Thank you very much for the reply!
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
I just left mine out and replaced it with nut, bolts and washers.
Disclaimer: The Ty member known as "revster" does NOT know better then the OFT boys. If "revster" strayed from the instructions he did so at his own risk and anyone that follows him down that path may suffer the same fate.
hittoomanytrees
I cut mine off. Took a few minutes with the hack saw and then a file to take off the edges.
I think I read that someone on here just bent it out of the way.
09Nytro_XTX
hittoomanytrees said:I cut mine off. Took a few minutes with the hack saw and then a file to take off the edges.
And you do not have to re-install it then correct? thank you for information!
Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
Relocator
When I installed mine I just cut the hook off there is no need for it.
snow broke
Re: Relocator
X2 Just clean up the sharp edges....I used a dremmel, which worked fine.
Yama 1000 said:When I installed mine I just cut the hook off there is no need for it.
09nytro
09Nytro_XTX said:hittoomanytrees said:I cut mine off. Took a few minutes with the hack saw and then a file to take off the edges.
No you dont re install it you rerout the cables and wires ......good luck ...
