BombaPolaYama
You're welcome, w/o the tank removed I couldn't see any way to get the bolts out, although someone on here said they used a pry bar! Awesome design on these machines ...... I think they were put together backwards or something!!Cubby said:Nice - thanks! Wow with the gas tank off there is tons of room!![]()
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Installed mine today. It took me longer than expected but once I loosened the gas tank and just slide it back a quarter inch it all went well. The hardest part was keeping the oilite bushings in place while I put it all together. It removed all the forward/back play in the steering.
Next I have Ulmer front end bushings on order but I think I will have the dealer install them when I take it in for its oil change/checkover.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Cubby said:Installed mine today. It took me longer than expected but once I loosened the gas tank and just slide it back a quarter inch it all went well. The hardest part was keeping the oilite bushings in place while I put it all together. It removed all the forward/back play in the steering.
Its easy to take the front end out. Cannondale has a great step by step posted in the "how to's" on taking the front end off.
That would give you easy access to the oil filter along with the a arms, and you could also do upbushman's kit for the steering.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
BombaPolaYama said:You're welcome, w/o the tank removed I couldn't see any way to get the bolts out, although someone on here said they used a pry bar! Awesome design on these machines ...... I think they were put together backwards or something!!![]()
I'm the pry bar guy! I was able to do mine without taking out the tank. If I remember correctly, it was mostly the wiring bundle that restricted the bolts from coming out but it was still a biatch.
Cubby
- Dec 14, 2009
I had to use the pry bar to move the wiring out of the way too and push in the bolts.
- Nov 1, 2009
- 2009 Phazer RTX
Got mine today. They look like VERY well built pieces. Looking forward to getting it installed.
dirtybeasher
- Feb 7, 2011
Sweet thanks. I usually do a search before I post a dumb question. But was havin beers and not thinking.
