oil breather hose
eclipsegst
norway
hey im new here, and my 2007 phazer with mcx turbo is leaking alot of oil out of the oil breather hose when im boondocking and when it rolls over! :(
anyone have a mod or tips ???
eclipsegst
I have a kit for this. It is designed to prevent the oil from leaking out when the sled is on its side. (engine not running)
http://www.ty4stroke.com/viewtopic.php?t=76357
Here are some pics of it installed on a Mtn-lite
eclipsegst--
Installed one of Mtn Viper's kits on my Nytro.
Works as advertised, simple install, no mess.
Going to be ordering one for the GF Phazer because if you drop it just wrong and it sits downhill, upside down, engine off (I installed a tether) it pukes oil all over itself and worse all over the clutches.
You can imagine being in the snow, gloves off, stuffing ice on the clutches trying to get them clean (or at least useable) and clean the belt off--- it sucked!
Buy the kit!
Does that teeters swith on you oil kit also turn off the engine if it comes off because I need to install on for drag raving anyways
Yes, the tether kills the engine and closes valve to the oil tank at the same time.
