fr0st
- Nov 25, 2013
got about 3 tanks of fuel burned and noticed it took a little oil..
also noticed that the oil pan Allen bolts were not screwed too tight so i did the ones i could reach.. not sure if the leak comes from there..
oil went down about 1/4 of an inch on dip stick.
last season it would take oil too.. not sure why though.. is it normal for these engines to burned a little oil ?
i would assume yeas since they run al day at high RPM..
what says you. ?
what says you. ?
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
- 2015 SR Viper XTX 2009 Yamaha Nytro XTX
Mine doesn't use any. I change once a season. Been ranging from 1,000-1,800 Kms per year. Are you actually seeing oil leaking?
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
x2
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Mine doesn't either
fr0st
- Nov 25, 2013
Well juste noticed there is a small puddle beneath the oil pan..
and the oil sump is wet from oil... anybody got an idea where that would come from ??
fr0st
- Nov 25, 2013
just found this intresting article
http://www.ty4stroke.com/threads/2008-nytro-oil-leak.83619/
this may be my problem..
i'm checking my oil COLD.... and trying to keep it at the top of the TOP of the cross marks.
i'll start with cleaning my air box and lower the oil level at 50% of the cross marks... with oil warmed up.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
The oil check on these engines is fickle. Gotta check them after its been run and up to temp, and the system has been circulating. Overfilling they will puke oil back into the air box and it will drip out on your floor. Been there, as many of us have. Good luck. MS
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You might want to pull your belly pan these machines are known to wear a hole into the filter from a the plastic webbing on the belly pan. Especially if you use an afetermarket filter.
- 9K
