margent
- May 1, 2014
Still new to yamaha and 4 stroke , I just got an 09 RTX and finally took it for a little test run once I stopped it was idling real rough and I noticed the oil light and engine light were on , played with throttle a bit and they went out and was running great again . When I pulled back in the garage I checked the oil and it was way over the H mark.
Will to much oil cause this ? the previous owner said he just changed the oil at the end of last season.Should I change again and start from scratch or just drain some .
Any thought?
Any thought?
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
Get a turkey baster and a small piece of hose to fit it and suck some out form the oil tank until you are just below the H mark. Much easier then pulling the belly pan and trying to drain some that way. If the oil looks like it wasn't changed , then I would change the oil and know for yourself that you have the right oil in there and the right amount.
Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
There's a drain plug on the oil can.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Make sure you are checking it properly. You "do not" screw the dipstick in. You mearly rest it on the top of the hole.
margent
- May 1, 2014
Thanks for replies , I did not scew in ,if I did level would have been even higher. Will that cause the light(s) to come on ?
canoehead
- Jan 14, 2011
- NE, Alberta
No it will not. It will give an inaccurate reading tho. Why did the guy sell it? Does it have a roll over valve?Thanks for replies , I did not scew in ,if I did level would have been even higher. Will that cause the light(s) to come on ?
Yannie
- Jan 5, 2014
- Winnipeg
Do you not have a code on the display as well?
margent
- May 1, 2014
No Roll over value that I know of. I did not notice a code .Like I said the engine stuttered a cpl times than lights went out, it happened fast .The sled does have Hauck Fuel Accelerator.
