APEX 21
- Jul 21, 2005
- Pardeeville, Wis Northwoods & UP
Does anybody know if the oil filter is going to be above the hatch like on the Rage/Vector. Or are we going to have to remove the air box and battery/box. I hope its above the hatch.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Same place as on the RX-1.
APEX 21
- Jul 21, 2005
That bites
MadMax
I "THINK" it may have a trap door like the vector... Look very carefully at photos on some of the ads.. Hmmmmmmmm Looks like my vector trap door under there......... :ORC
MM. P.S. The filter will be on the front half of the motor.. But the secret trap door looks like it's up there with it...MM.
MM. P.S. The filter will be on the front half of the motor.. But the secret trap door looks like it's up there with it...MM.APEX 21
- Jul 21, 2005
There is a trap door on the 03 RX-1, but it opens to a crankcase drain plug.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Yep, that's correct.APEX 21 said:There is a trap door on the 03 RX-1, but it opens to a crankcase drain plug.
Pullinfront
From looking at the oil filter at the shows last winter it looks like you can get to the oil filter very easy. We should be able to get to the filter from the front were the old 2 can storage box use to be. I asked the Yamaha rep there but he was not sure if it was going to change or if it was possible to get it out that way. It sure looked like it would be easyer to me.
Pullinfront.
Pullinfront.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Allen you have an Apex, is it any easier?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Don't think you'd be able to get it out that way. Maybe, but you wouldn't be able to see or clean up the oil mess that spills out.
Bodacious
Is the relocating filter kit a worthwhile investment? Are there any other components that need to be inspected in the general area that the original filter location is mounted? ( if so it would seem that it would be better to leave it where it is.) Finally, if the oil filter relocating kit is installed, does the oil run at a cooler temperature? I would think it would have a better chance of cooling located off of the engine base.
