RX1Jim
Has anybody bought the oil filter relocation kit?  Maxx Perf has one for $159 and Bender has one for $179.  I like the idea but have concerns about the type of hoses they are using.  I may make my own aluminum housings and use some high pressure steel braided hose to ensure reliability.  It would be an instant nightmare to lose a hose or hose clamp in the middle of long trip in Quebec.  Where do they suggest relocating the filter to?
			impalapower
How long the hoses are determines your location.  The hoses and fittings are probably hydraulic and can withstand far more than the pressures that the sled puts them through.
			Mighty
 - Apr 17, 2003
 - Grand Ledge Michigan USA!
 - 22 Mach Z
23 Sidewinder SRX
Put your money towards an ECP K&N kit and get a performance boost as well as easier access to the oil filter.
			kinsound
ECP K&N kit
Is that a safe and easy install? I still cant find the oil filter even after taking the air box and battery out....I will search for topics on it but need to know the pros and cons..
Mighty
 - Apr 17, 2003
 - 22 Mach Z
23 Sidewinder SRX
Look underneath the battery bracket.
			I can think of alot better things to spend $150+ bucks on.  Once you do the first oil change, which is a bitch because everthing is so
  tight, the rest are easy. Besides you only do them every 2,000 miles or once a season.
  tight, the rest are easy. Besides you only do them every 2,000 miles or once a season.sledheadgeorge
 - Apr 28, 2003
 - Which one? I have 6
YOU CAN ALSO DO THE BATTERY RELOCTION INTO THE FRONT LOWER BELLY OF THE SLED.  REMOVE THE METAL BATTERY TRAY. SAVE WEIGHT AND NOTHING IN THE WAY FOR FUTURE OIL CHANGES.
			impalapower
RX-1 Man has a valid point.  You generally change oil only once a season.
			LazyBastard
Is it really worth $160 to save 10 minutes of work every year (oil change time from 30 mins to 20 mins)? You can hire a flunky for $10 an hour to change your oil and the $160 will pay him for 32 years worth of oil changes (assuming 30 minutes per oil change) and you don't even get your hands dirty.
			kinsound
I was really refering to the ECP K&N kit. But i like the flunky Idea No sense getting dirty
 - Mar 1, 2004
