rx-1erlimitededition
Does anyone know if Yamaha sells an oil filter wrench for the RX-1 or Apex filters. Does anyone know the part number and where I can get one.
grader
save your money, channel lock pliers work great.
Nice Rumble
If you can't spin the filter by hand tighten a large hose clamp around it leaving the clamp screw exposed. Tap the screw gently with a long screw driver and hammer counter-clockwise to loosen it. Then spin it the rest of the way off by hand.
Nice Rumble said:If you can't spin the filter by hand tighten a large hose clamp around it leaving the clamp screw exposed. Tap the screw gently with a long screw driver and hammer counter-clockwise to loosen it. Then spin it the rest of the way off by hand.
Great idea!!! I never would have thought of that.
happytrails
- Apr 29, 2005
- Stockbridge, Mi
- 2018 sidewinder ltx-le
Yamaha Part # YU-38411 will fit rx 1 and apex, vector filter is different size.
YamiSmurf
Push a screwdriver through the middle of the filter and turn. Works great, just a little messy.
YS
YS
stinx
strap wrneches work great also
Mrplow
- Sep 18, 2005
- Madison WI.
- www.proscapesllc.com
I just used my automotive wrench?????????It worked as well?????????
I only tightened it hand tight, instead of factory cranked like hell.
- Mar 1, 2004
Rubber type Mech Glove........Works Great, Your Hand Won't SLIP OFF
grader said:save your money, channel lock pliers work great.
I use the channel lock to loosen the filter and only go hand tight for putting one on. Have not had a problem ever.
