02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
I was going through my sled, checking things out, when I looked into my airbox, and found oil/water mixture from my ROV hose is dripping into my airbox and saturating my filter. On the 20's there is a new hole drilled into the back of the airbox, with the hose routed inside the filter. This makes no sense to have this happening right above the clutches and belt. There is evidently moisture mixing with oil to cause the milky white discharge from the hose. Less than 500 miles and never been on its side.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Yup same thing on mine,
I noticed that liquid on my Percision lower panel guard at only 800km and I had a lot dripping down out of the air box, also had a big chunk frozen inside my air box.
https://ty4stroke.com/threads/quick-ltx-gt-report.159191/
Scroll to page 3, you will see a way to bypass the hose going into the filter box.
I guess it’s a emissions thing, hate to say it but I just added a barb connector and added a piece of hose to under the motor.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
So they have changed this from the earlier models evidently, they used to dump the oil residue crap back into the charge tube just prior to the turbo.
Now the idiot engineers have decided to dump it into the airbox and let it run into the clutches when it builds up, saturates the filter and starts dripping out. Good grief, what morons!!!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Luckily the air box is tilted forward so the oily water runs down the front of the lower panel and not directly onto the clutches and belt lol..So they have changed this from the earlier models evidently, they used to dump the oil residue crap back into the charge tube just prior to the turbo.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Missed your post. But yes, that hose with an extension, shall be re-routed.Yup same thing on mine,
I guess it’s a emissions thing, hate to say it but I just added a barb connector and added a piece of hose the under the motor.
Just the same old same old. We all had it back in 2017. I guess they found a new way to pre oil the filter!
https://ty4stroke.com/threads/check-your-air-intake-clutches.144260/#post-1314538
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Yes, but yours was a substance added to the filter. Seen my friend's 17 SW with it on. This was plumbed into the airbox, with oil leaking into it. The backside of the airbox was cut with a hole saw for this hose from the ROV. No foresight to oil on the clutches in the long runJust the same old same old. We all had it back in 2017. I guess they found a new way to pre oil the filter!
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
I have found that build up of white oil in the large tube behind my air filter every time I take the foam filter off - as has my buddy. Very simple to wipe out with a rag. 4,000 miles on mine and 7,000 on my buddies and it hasn't been an issue for either of us.
Yes I understand. It was a little tongue and cheek. The engineers never cease to amaze us with their foresight.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Anybody else have any issues? My mechanic rerouted with a 90 elbow and a hose added.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Did you plug the hole in the air box?Anybody else have any issues? My mechanic rerouted with a 90 elbow and a hose added.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
No, went to a CAIDid you plug the hole in the air box?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Nice..
Before last weekends ride which was about 760km, I just routed the hose to on top of the belly pan where you remove the oil filter and yesterday I took a look and you can clearly see quite a bit of the oily water all over the place.
Todd Beenen
I just had this happen on my cat, so you guys just reroute the hose going to the air box? You plug the hole where it mounted ? Mine had a lot of oil in it plus all over where it dropped out airbox .I was going through my sled, checking things out, when I looked into my airbox, and found oil/water mixture from my ROV hose is dripping into my airbox and saturating my filter. On the 20's there is a new hole drilled into the back of the airbox, with the hose routed inside the filter. This makes no sense to have this happening right above the clutches and belt. There is evidently moisture mixing with oil to cause the milky white discharge from the hose. Less than 500 miles and never been on its side.View attachment 152861 View attachment 152862 View attachment 152863 View attachment 152864 View attachment 152865 View attachment 152866 View attachment 152861
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes, plug the hole and reroute the hose, clean up the oil and you’re good to go.
