Oil leaking into spark plug hole
ReX
Ottawa, Ontario
When I installed a set of new plugs a couple of days ago I noticed the PTO side spark plug hole had a little oil in it.
Not much, just about the equivalent volume of a single drip that had run down into the spark plug hole.
It looks like it is oozing from the gasket between the valve cover and head.
Is this a common problem? Should I worry about it? Does it typically get worse?
