Dr. FeeLGooD
They are discussing this in a motorcycle forum I frequent. I think it may work better on our sleds, if there is one that fits.
https://www.fumotooildrainvalve.com/
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I don't think that there would be enough clearance underneath the pan to the bottom cover. Also if you had a bottom impact it could break off causing catatsrofic engine failure.
Ken...........
Ken...........
gouldsjett1
I have one of the drain valves on my Duramax truck. It works great but not enough room to install on an Apex, I tried .
4kops
I handle one that is a little nicer made by Ez Drain
radianguy
- Jan 1, 2007
I have a fram sure drain on my motorcycle, never saw the need on my sleds.
Ulmer Racing TD Max a Viper owner here designed the kit. So easy doing oil Changes!
https://shop.ulmerracing.com/EZ-Dra...&browse=-73647&shopby=-26776&catalogid=-11683
kviper
I have the tank drain kit from Ulmer on my Sidewinder. Works awesome!
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have a Stahlbus drain valve on my Viper. It has a ball check and a cap, not a lever like the Fumoto valve. I run a Stahlbus valve on my 14 F-150 Ecoboost truck as well.
https://www.stahlbus.com/info/en/products/oil-drain-valves
