I was reading an old post about oil pressure gauges, and what is reccomended. Someone asked about where to tap in for the oil pressure reading, but there was never a reply for it. Has anyone here installed an oil pressure gauge, and if so, where did you plumb in the sending unit? I would think it would be pertty straightforward to just tee off where the existing sending unit for the light is mounted, but I haven't actually seen the location so I don't know if it would work. Also, which gauge did you use? I found nice digital water temp and oil pressure gauges from Summit Racing, which should eliminate any problems caused by vibration and cold weather. www. summitracing.com oil pressure part number SUM-G2985 and water temp. part number SUM-G2984. I know the digital gauges aren't what a racer would want for simple clarity, but I think they would work well as a backup for the existing lights and at least give you a better idea exactly what the readings are.
Jim
