Sapling
What size oil restrictor is everyone using?? What size gives the proper flow? I seached but could not come up with any of the threads that this was discussed in last year about using jets drilled out to a certain size.
Any links would be great.
Sap
Sap
tonykof
zx670
in basic, .035 for ball bearing turbos, .060 for journal bearing turbos, in the feed line of course. most ss braided lines can be tapped for 5mm to accept std mikuni pilot jets, not sure what size equals what but drilling to recommended hole size works well
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
I put a set screw in the center section of the turbo housing with the .035 hole drilled in it. I believe it is a 4mm thd.
JIM
dave told me to use a 90 mikuni pilot jet in the oil line that you have. Just tap the oil line where it meets the tee down by the oil presssure sensor with 5mmx0.8 tap and screw it in there and that is about .035. I put one in mine.
Jim
Jim
Ted Jannetty
zx670 said:in basic, .035 for ball bearing turbos, .060 for journal bearing turbos, in the feed line of course. most ss braided lines can be tapped for 5mm to accept std mikuni pilot jets, not sure what size equals what but drilling to recommended hole size works well
Correct!
Guys will Ask How do I know if I have Ball Bearing or journal Bearing?
You must Check the Tag Riveted to the center section and check with a Garrett Dealer.
Look for a part number resembling (466541-5004 or -04)
And for those Turbo Kit companies that Purposly remove the Tags Because they think they have some big secret, you must call them and ask.
Most all the turbo kits I know of come with Garrett Ball Bearing turbos.
Ted.
snowy1
Ted Jannetty said:zx670 said:in basic, .035 for ball bearing turbos, .060 for journal bearing turbos, in the feed line of course. most ss braided lines can be tapped for 5mm to accept std mikuni pilot jets, not sure what size equals what but drilling to recommended hole size works well
Correct!
Ted.
as Ted said and in my opinion if they won,t tell you up front what turbo is in the kit, there not worth dealing with, I want to know what I have in my sled. its not that hard to measure and find out, so its really not a secret.
SPEED
JIM said:dave told me to use a 90 mikuni pilot jet in the oil line that you have. Just tap the oil line where it meets the tee down by the oil presssure sensor with 5mmx0.8 tap and screw it in there and that is about .035. I put one in mine.
Jim
I just finished tapping and installing 90 jet, had one laying around.
I see on your site Ted that you stock a fitting, that is much easier to do if I wasn,t in such a hurry I would have ordered one
Ted Jannetty
SPEED said:JIM said:dave told me to use a 90 mikuni pilot jet in the oil line that you have. Just tap the oil line where it meets the tee down by the oil presssure sensor with 5mmx0.8 tap and screw it in there and that is about .035. I put one in mine.
Jim
Thanks, Yes we have several different restrictors to fit most turbos.
- 147K
