monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- Anyone ever have this before?
- I took the sled in for a pre-season check up and also asked them to look at a small oil drip that appeared over the summer while she was on the trailer.
- I had my drive chain replaced late last year, and thought that it might be residual oil, but the dealer tells me that I have a hairline crack in the oil tank.
- Any ideas on what woulda caused this?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Yap both of my apex's need new ones.
monte1214
- Apr 20, 2005
- Durham Region, ON
- Any ideas on what's causing it?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I'm think it comes from the hitting bumps over and over that it just weakens it.
monte1214
- Apr 20, 2005
- Durham Region, ON
- Odd??
- Don't these things FLY over the rough stuff!
- Thanks for the input 06.
TechMaples
- Nov 9, 2007
- Monticello, ME
- 16 Zr 8. 20 Riot 8. 98SRX
- Monticello
Put a rubber washer in between the lower tank tab/mount and the bracket with the stud. Vibration causes the cracking issue.
quebec#1
Both my friends 2006 Apex and attack had the same problem. Was this only with the 2006's ?
monte1214
- Apr 20, 2005
- Durham Region, ON
KatahdinLodge said:Put a rubber washer in between the lower tank tab/mount and the bracket with the stud. Vibration causes the cracking issue.
- Thanks!
monte1214
- Apr 20, 2005
- Durham Region, ON
quebec#1 said:Both my friends 2006 Apex and attack had the same problem. Was this only with the 2006's ?
- It'd be nice to know of it was!??!
- This is my 1st Apex,a nd I've already done the drivechain and now this.
- I'm takin' alot of flak from my Poo and Ski Dog friends.
quebec#1
chaincase yes their was some problems on the 2006's also someone told me about the coolant bottle had some sort of leak on the 2006's
monte1214
- Apr 20, 2005
- Durham Region, ON
- I'll be sure to check it!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Would some J/B Weld or something similar not work for repairing this?
Thinking it might save you some money John?
I have a putty you mix together, just kneed it until consistantly grey and apply.
It hardens like steel and can be drilled, tapped and grinded, it works great.
I did my rivets on my old boat and they never moved or leaked anymore water after I did this, lasted for 6 years when I sold my boat and they are probably still on there?
let me know if your interested.
monte1214
- Apr 20, 2005
- Durham Region, ON
Irv said:Would some J/B Weld or something similar not work for repairing this?
- Yeah, I know JB Weld Dale.
- Too late though...I ordered a new tank on Friday.
- Thanks for the help!
- I'll be at work tomorrow riding the "double bubble" "gravy train" for 10hrs, so that should cover it!
number1kyster
My 07 cracked last year with 10K miles on it. It was replaced under YES.
Maxout01
Where on the tanks do the cracks develop?
