Oil Tank Removal
I've had good luck with yamabond. The key is making sure both surfaces are oil free and clean.
I can’t see yamabond 4 working well. It’s too thin and kinda self levels. You wouldn’t be able to get a good bead and be able to let it tack up.
Yeah that was my thought process as well. Works good on crankcases. I ended up using permatex ultra black which is similar to yamabond 6b.
Bringing this back up today......
Im guessing that many of you guy who have not already found seeping oil tank seals, will find them seeping this fall. I think its inevitable that these all do it sooner or later. Mine did it even though I installed ROV delete within first hundred miles or so.
Sure we can re-seal them....but I have thought from the get-go that a new tank would be a great item for someone to build and would likely sell a boatload.
Been in contact with someone and will see where this goes, just early stage as of now but I think this might be a better solution in the end. When I know more Ill start a new thread.
Dan
Mine leaked and my dealer fixed it after the season was over.
View attachment 137635 View attachment 137634
Just did mine yesterday there’s a groove Dan easy to do. One ride with only 550 km on the sled.roll over valve mod done at 39 km it was new old stock
And also I thank cannondale give me some info
How many miles your sled had on this pictures? 550?
I don't like this, it's pretty deep after 10 500km. Plastic oil separator has create a chanel
Yes 550 km on it and ok are your plastic separaters silicone in they should not move how deep is the groove
O.076. I know Its not the end of the worl..... BUT this shredded metal go through our engine:ban:
Looks like it's already been resealed at least once ?
Yes you are correct that would create some problems. How many kms on your sled I guess this is another thing to watch for. Look at your oil see if any metal in it ? What’s the other side look like plastic. I was looking at others and pictures on forum and look like yours as well.
Can’t believe someone hasn’t come out with an after market tank that is self contained. Upgraded my nytro s oil tank after the stock tank mount’s broke - jagged customs was the name of the company.
I had sent them an email about making one for the sr chassis with no response.......
Gotta believe it can be done. Take the same design from the nytro tank and change the mounting holes
Ms
