vector_1
I am checking around to see who mfg.'s 0W-30 for my Vector. Come to find out that I can only get CASTROL 0W-30 full synthetic in my area at $5.50 per quart. My local dealer has the YAMAlube semi-syn 4cw 0w-30 for $7.59 per quart.
Can I use 5W-30? When I called another dealer he stated that they are using 5w-30 in all of their oil changes on the RS sleds. WHAT TO DO??
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
Buy the Yamaha oil. I mean seriously with all the money we put into this sport you're going to worry about maybe spending an extra $10 for an oil change?
canadianhunter
I also have a question.
Is the Yamalube 5/30 mineral oil with synthetic additives ?
If so maybe it would be the stuff to use on the 500 mile change for the remainder of the 1st year [insure a good breakin] and then go to Yamalube 0/30 synthetic blend.
Your thoughts.
Your thoughts.
vector_1
The 5w-30 that this dealer uses for oil changes is the semi-syn "4S" variety, not the 4CW.
If that is the case, can I not use a high grade 5w-30 semi., just not Yamaha's propietary brand?
STORM-CHASER
you can do what ever you want ,But if it was me I would use the Yamaha oil.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Use the Yamaha recommended oil. For the last two seasons, they have had the semi-synthetic blend out and it works extremely well, plus it enables the sleds to start easier in cold weather.
vector_1
Thanks to all for the advice. Went to my dealer today and had him order me a case of the YAM 4cw 0w-30 for me. $7.00/quart
Ole Timer
For $20 bucks a year you can become a Preferred Customer with AMSOIL one of the, if not the very best money can buy synthetic oils specifically designed for your four stroke Yamaha in 0-30 or 0-40. Cost around $4.75- $5.00 a qt. GETTER DONE !
You don't really think Yamaha makes oil do you ?
You don't really think Yamaha makes oil do you ?Tom-RX1
I use mobil 1 10-30 works great and is cheep at walmart or canadiantire .
Tom-RX1
Tom-RX1
STORM-CHASER
[/quote]there has been a guy selling it on ebay for $48.00 a case http://cgi.ebay.com/ebaymotors/YAMA...wItemQQcategoryZ100449QQitemZ4590688122QQrdZ1quote="vector_1"]Thanks to all for the advice. Went to my dealer today and had him order me a case of the YAM 4cw 0w-30 for me. $7.00/quart
QCRider
- Feb 27, 2004
- www.myspace.com
Ole Timer said:For $20 bucks a year you can become a Preferred Customer with AMSOIL one of the, if not the very best money can buy synthetic oils specifically designed for your four stroke Yamaha in 0-30 or 0-40. Cost around $4.75- $5.00 a qt. GETTER DONE !![]()
So now it costs $40 to put oil just as good as the oil Yamaha sells in my sled? $20 for the preferred customer status and $20 more to fill it up. Glad you like it, that's cool, but the synthetic I get from Yamaha works fine for me.
vector_1
Okay...okay. Can we all just agree to disagree. I was only curious if 5w-30 was an acceptable replacement to 0w-30. Untimately, Yamalube will work just fine for me. I really do not like using Yam's proprietary oil(No, I really do not believe that YAM produces their own oil. I know that someone else mfg. it and it is labeled for YAM)
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Lighter weight oil enables the sled to start easier when it gets really cold, like -20C or colder. This applies regardless which brand you buy.
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
vector_1 said:Okay...okay. Can we all just agree to disagree. I was only curious if 5w-30 was an acceptable replacement to 0w-30. Untimately, Yamalube will work just fine for me. I really do not like using Yam's proprietary oil(No, I really do not believe that YAM produces their own oil. I know that someone else mfg. it and it is labeled for YAM)
When the 2003 RX-1 first came out the specified oil was 5w-30, Yamaha switched it to 0w-30 in 2004 or 2005.
As someone stated above the main reason to switch was extreme cold starting. If where you ride it doesn't get extremely cold (like below -15F) then 5w-30 would be fine.
STORM-CHASER
You said you had your dealer order the 4cw , but what you want for the vector is 4-s Sae ow-30vector_1 said:Okay...okay. Can we all just agree to disagree. I was only curious if 5w-30 was an acceptable replacement to 0w-30. Untimately, Yamalube will work just fine for me. I really do not like using Yam's proprietary oil(No, I really do not believe that YAM produces their own oil. I know that someone else mfg. it and it is labeled for YAM)
