mattchew_3
- Dec 28, 2014
- SR Viper
Can you run the 8DN belt with just the OSP adjuster? Does anybody run their clutch kit too? Looks like a decent deal under $300 or should I just get the Ulmer be done with it?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I run the OSP adjuster and run an 8DN. You will need to remove the bolts and washers from the back of the secondary.
As to clutch kits, they are a separate issue. Yes the belt makes a difference but having the OSP adjuster should not affect the clutch kit you use.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I run Ulmer's trail clutch kit, OSP belt adjuster and 8DN belt. Work awesome!!
Birkebeiner
Birkebeiner
mattchew_3
- Dec 28, 2014
- SR Viper
What are you seeing for top end?
