grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I'm not sure about it's long term use but the lack of float at engagement just doesn't seem like a good thing. These clutches need to float for proper alignment and if for some reason the adjuster doesn't allow for proper alignment that would cause unnecessary stress on the belt. Shimming takes very little time or effort and to me works well enough to continue adjusting the way Yamaha designed them.
I like simple and you can't get much simpler than a bolt and shim washer.
