Tunepipe
- Oct 5, 2014
- Sormany
- VkPro, Venture TF, Phazer, Snoscoot 200...Sidewinder, Excell III
Hello everyone, like the subject says, installed MCX 190 on a 2015 Viper, 1000kms on unit, boost pushes over 8 PSI, anyone getting the same issue ??? Anybody here running an MCX 190 at sea level ??? Played a bit with wastegate rod <lenghtened> but still too high boost...help.
CustomApexMan
Where is your boost gauge sencor/reference point it will read high if not on the engine side of the throttle plates. It could also be the altitude bypass compensater located on the turbo with the 2 wire plug
Tunepipe
- Oct 5, 2014
- Sormany
Boost gauge is connected with a T fitting to the intake manifold. As for the 2 wire altitude compensator is there any way to test this ??? We have 3 kits on the go and all are over-boosting, and now 1 of them blew up. So I'm sure my boost readings are pretty accurate (too high). Thx
CustomApexMan
The compensater bleeds pressure off that the waste gate sees so if you put a hose straight from the compressor housing to the wastgate you would be at the lowest opening pressure the wastegate would allow. Or just take the two hoses off the compensater and connect them together
Tunepipe
- Oct 5, 2014
- Sormany
Yes...I read about connecting both hoses and this should drop boost , will try this tomorrow. But is there another solution you think ? Or should I use this "bandaid" fix ? Thx for you input. I'll fill you in tomorrow night on my testing.
CustomApexMan
Mine is right on 15.5lbs at 1000 ft. 15lbs at sea and they rough at .5lbs per 1000 ft
Tanker Yanker
- May 4, 2014
- Davidson SK
- 2015 Yamaha Viper XTX LE
2009 Yamaha Nytro RTX
I have the MCX190 and is set at 6.5lbs at 2000 ft.Mine is right on 15.5lbs at 1000 ft. 15lbs at sea and they rough at .5lbs per 1000 ft
Tunepipe
- Oct 5, 2014
- Sormany
bypassed solenoid directly, still too much boost, MCX canada will change the map, sent out boxes for re-map, praying this works.
CustomApexMan
With the solenoid bypassed the only thing that controls the boost level is the wastegate. Mabey they have 8lb wastegate installed instead of a 6lb
john ca 99
- Sep 2, 2014
- muskoka ontario
- 2015 ltx viper
hi I would like to no how you made out with this over boost I have mcx kit on order not sure I want to fight with that as soon as I install thanksHello everyone, like the subject says, installed MCX 190 on a 2015 Viper, 1000kms on unit, boost pushes over 8 PSI, anyone getting the same issue ??? Anybody here running an MCX 190 at sea level ??? Played a bit with wastegate rod <lenghtened> but still too high boost...help.
Tunepipe
- Oct 5, 2014
- Sormany
Sure will john ca 99
john ca 99
- Sep 2, 2014
- muskoka ontario
- 2015 ltx viper
you probably do have high boost wastegate spring
Tunepipe
- Oct 5, 2014
- Sormany
Nope. Manually checking it opens at 4psi. But still over-boosting.
john ca 99
- Sep 2, 2014
- muskoka ontario
- 2015 ltx viper
is arm binding as its openingNope. Manually checking it opens at 4psi. But still over-boosting.
