over the summer mods??
I think a 4000 duckets for a supercharger is a good dealy for 130 HP's ,,that might be the summer project this year.
x2
Mildly boosted or NOS'd would give the best dollar per hp
I am thinking about getting my riser taller by 2.5". Can I do thins with the stock cables/wires?
I put the Yamaha MTX 3.0" rise hooked bars on and its perfect now, great position, however the cable is too short , makes it too tight one way, so i got the powermadd throttle cable extension , its a POS but it works makes the cable almost too long so had to route it quite funny through the bars but its working well now.
So i will have to extend the throttle cable? What if i just put one from an MTX in?
I used the Powermadd riser with stock cables. If I remember correctly I just had to reposition them a little.
Thanks, I go ahead with the riser this summer and if it looks like i need more cable il just get an extension.
I installed a PowerMadd PowerRiser 325 2" riser on my sled. I had to re-route the throttle cable under to get it to fit properly. It is as tight as it can be without triggering the TORS code. I had to play around with its position (pivot) quite a bit until is stopped throwing a code on tight turns. Anything over 2" needs a throttle cable extension.
Its a huge improvement when standing (I'm 5'11').
I am 5'9" and the bars are perfect for my height. Funny that you are exactly 2" taller than me and you put a 2" riser on.
These must be aimed at a 5'9" body I suppose.
