journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
(motorcycles, not bikes with human power!),.
So I can’t interest you in riding my mountain bike trails over here I take it? LOL!!
SledFreak
- Feb 7, 2005
- Ontario. Canada
So, as the snow is gone and I have to change my oil... Whats the consensus? 5w30 Full synthetic or 0w40 full synthetic. Whats everyone running?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
0 30. Full syn.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Want a good 5-30 that can be bough at reasonable cost at even Wal-Mart, use the Quaker State full synthetic Ultimate Durability. Ranks very-very high on 540Rat testing/blog. I wouldn't use a 40 weight in the 998 myself as it will rob some HP from it vs a 30 weight oil. Seen that first hand before unfortunately.
https://540ratblog.wordpress.com
Fast
- Sep 25, 2018
What about the 5 weight? I thought the 0 weight was more crucial on extreme cold starts, dont we want 0w30Want a good 5-30 that can be bough at reasonable cost at even Wal-Mart, use the Quaker State full synthetic Ultimate Durability. Ranks very-very high on 540Rat testing/blog. I wouldn't use a 40 weight in the 998 myself as it will rob some HP from it vs a 30 weight oil. Seen that first hand before unfortunately.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
The difference between the 5 and the 0 is minimal, but the cost is much more.
5w-30 is much easier to find.
I couldn't even find 0w-30 this year unless i ordered it.
I think 0w-30 is good to -35 and 5w-30 is good to -30.
Not enough to debate over unless you live in an extreme Arctic environment.
OR, you have OCD!
OR, you have OCD!
SledFreak
- Feb 7, 2005
- Ontario. Canada
Actually found some 0-30 Mobile 1 Full synthetic on sale right now for 29.00 CDN. Thanks..
CT?Actually found some 0-30 Mobile 1 Full synthetic on sale right now for 29.00 CDN. Thanks..
SledFreak
- Feb 7, 2005
- Ontario. Canada
yes... and wow did you stock up..
SledFreak
- Feb 7, 2005
- Ontario. Canada
What about the 2 Orings/washers, should I change them out? If so, what's the part numbers? This is my first oil change.
That's from last fall, and I actually ran out in March.yes... and wow did you stock up..
They have stellar prices on oils often.
Do a visual inspection, but that 0-ring usually is chewed up. I use the copper washer over. Don't over tighten the drain plus when re-installing.What about the 2 Orings/washers, should I change them out? If so, what's the part numbers? This is my first oil change.
Also, try not to get oil on the foam under the muffler.
KnappAttack
- Feb 19, 2004
- Welch MN
0-30 Mobile One is not rated very high on Rats testing/blog for wear like the 0-40 is.
The difference between 0 and 5 weight is not that important if that's what you are worried about. I'd go with a higher rated oil for the 998 but that's just me. Prolly better than the 0-30 Yamalube at least.
0w40 Mobil 1?0-30 Mobile One is not rated very high on Rats testing/blog for wear like the 0-40 is.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Rubber o ring for oil tank drain plugWhat about the 2 Orings/washers, should I change them out? If so, what's the part numbers? This is my first oil change.
8JP-RAF05-00-00, copper washer for engine drain bolt 90430-06166-00. Engine bolt washer will be fine to reuse, order a few o rings for the oil tank as they are good to have on hand.
