Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
- Yamaha nypex mcx 400
Hello. Can someone confirm what map sensor this it? That one in front or that one on the throttle boddy?
P1106-00 (08)
Pops up everytime I rescan fault codes and cant figure out why. Tryed to change both but no different.
P1106-00 (08)
Turboflash
- Mar 18, 2019
- Southern MN
P1106 is usually MAP sensor issue. Either hose is off, or blocked (water/ice in hose), or it is non-functional all together. Since you replaced it, I would suspect issue with hose being blocked or leaking (could even be same problem upstream from MAP. Check all those hoses going to or from the solenoids; or electrical connection to MAP. Also, could be barometric pressure sensor problem.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Okei thanks. Will check all hooses, the fault code also says «dual generator lower fault».
Is the tune right to match the sensor?(If it's tuned)
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Yes that one in front is a 4 bar map sensor and tuned for that. That on the throttle body is stockIs the tune right to match the sensor?(If it's tuned)
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
All the readings in log for boost is spot on, so the sensor in front seems fine. But no different if I disconnect it when sled is running. The other sensor on throttle body kill the engine. I changed my ecu last year and the fault code was gone. But came back now.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
