PB-80 testing today
woodysattak
Union Grove WI
2017 RTX LE
LOCATION
Waterford WI
Took out the sled today wanted to fine tune the HH setup further and also wanted to fine tune the pb-80 more. A lot better conditions today than last week. Temps were about 20 and had plenty of snow to watch rpms on a little longer run. Trails were closed but had a nice hardpack trail on my land to run about 600 ft and also a couple fields to hold open for about 900 ft. Right now the pb-80 seems to be working extremely well. Its hard to explain the shift is so smooth and consistent. It pretty much a straight shift it comes out about 8800 and stays between 8700 - 8800 even when spinning and grabbing once in awhile down the track. I am going to northern WI next weekend I will put on about 200 miles its more of a relaxing trip with the wife. As of right now I prefer the pb-80 over any other setup. I have the HH and daltons. I was running the gates g-force and tried the stock belt because I have not even tried it yet. To my surprise it pulled the same rpms and ran cooler. Belt temps were cooler and also primary was not bad. I know you can't always go by seat of the pants but this clutch seems to mph faster. I can't wait to get it on regular trails and see how it performs. As of right now this is my setup of choice. As I said I can't explain it but very smooth and pulls very good also alot quieter than the yammie clutch. I will report back after next weekend. Thanks
What puller are you using to get the pb80 off
Its a puller that is made for the pb-80 on the winder. The doo puller is close to it but is a little. different. You can order through cvtech in canada.
How much was the puller?
