fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
Hey guys wondering if I can add pc5 and ign module in conjuction with the mcx box or better to go all pc5. my sled is lean everywhere even off boost cruising. mcx 290 apex 2011 ( exup removed )
fast n furious
- Jan 24, 2010
- Nova Scotia
anyone?
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
If you are going to run the ignition module I'am quite sure you will need to go with the PC-V so you may as well do away with the MCX box and control every thing with the PC-V. Another benefit of the V is launch control! I'am sure Allan Ulmer could set you up!
My MCX is lean cruising and was running around 13/1 WOT when I first put the kit on. I took a trip out by Allan and now it is still lean cruising (off boost) and runs around 12-1 WOT. I have talked to Maczrobie who has a lot of experience with MCX kit's and he says his runs lean cruising (off boost) as well.
fast n furious
- Jan 24, 2010
- Nova Scotia
removed mcx box and ran a pc5 with dave marshalls mapping and sled runs great now
kviper
- Nov 7, 2003
- Oakfield WI
Sounds great!
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Are you still using the MCX auxillary injectors or did you eliminate them to upgrade stock injectors with PCV?removed mcx box and ran a pc5 with dave marshalls mapping and sled runs great now
fast n furious
- Jan 24, 2010
- Nova Scotia
290 kit does not have extra injectorsAre you still using the MCX auxillary injectors or did you eliminate them to upgrade stock injectors with PCV?
BADSLED
- May 13, 2004
- Syracuse, NY
Looks like I may have to take a trip to Hurricane as well to have AFR table fine tuned this summer using PC3 or 5. Is there a significant benefit of going to PC5 over PC3? Not sure I am in need to launchcontrol option.
