wildbonz
Hi, I posted this on the General Yamaha forum as well.
Does anyone have a copy of, or link to, or pictures of installation of the ignition module and multi-function hub to the PCIII on an Attak?
Mine are missing and I want to get it set up properly.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
wildbonz
Thanks Dan, exactly what I needed. I appreciate your time and help.
This site is great.
If anyone has info on the hub, that would also be appreciated. I don't have boost or turbo, just using it to install the switch to change back and forth between maps.
thanks again
This site is great.
thanks again
wildbonz
I think I've got it figured out, pretty straightforward. Connect igniton to PCIII, hub to ingition and the switch cable is the only 3 pin connector coming out of the hub.
snolover
- Dec 1, 2004
hi i have fix motorsports ram air and excell muffler anybody recommand the pc111 and ingnition module does it worth the money
thanks
thanks
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
snolover said:hi i have fix motorsports ram air and excell muffler anybody recommand the pc111 and ingnition module does it worth the money
thanks
yes it can give you alittle more power for sure....
is it the end all be all?...no....is it worth money?....not sure since its pricey...but i like it so far.
Dan
