jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Anyone ever use these?
www.cbperformanceparts.com
Performance Stud Stars
Looking for snowmobile aluminum spindles and engine rebuilds in Chicago IL? At CB Performance Parts, we can perform nearly and service to your snowmobile.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Why use those when there are lighter and better Stud-Boy Pro-Lites out there? The plastic IMO is better with not holding the ice like regular backers and provide a paddle effect as well in certain snow conditions.
Been using the two hole Pro-Lites for years and never a problem. Just tap them 3/4 of the way thru and you're golden. Two-hole plate also proved better traction and support as well. I prefer not to use singles but I know to get the lines a guys needs to. Hers my track I just put on my sled. Had a single tear out on the outside band last year at 6200 miles so need to replace the track. Replaced it with the same setup but no quite lugs and fully clipped, which is awesome.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I could see this. Agree.. Going to give these a try and see.The plastic IMO is better with not holding the ice like regular backers
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Stud stars look so friggin horny tho! Bling!!
Hard to find though and not cheap.
KnappAttack
- Feb 19, 2004
- Welch MN
But you can't see them when they are just a big lump of ice.
Myself, I prefer to not attract attention to my studs and track...... Hence the black backers.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Incognito! I get it!
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Both new riots have these. Seems cheapest place to get them is directly from them. Install is ridiculously quick, just keep a spray bottle of soapy water with you to spray the track before you tighten them down.Anyone ever use these?
Looking for snowmobile aluminum spindles and engine rebuilds in Chicago IL? At CB Performance Parts, we can perform nearly and service to your snowmobile.www.cbperformanceparts.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Sounds good.Both new riots have these. Seems cheapest place to get them is directly from them. Install is ridiculously quick, just keep a spray bottle of soapy water with you to spray the track before you tighten them down.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thoughts on them? Working out on the riots?Both new riots have these. Seems cheapest place to get them is directly from them. Install is ridiculously quick, just keep a spray bottle of soapy water with you to spray the track before you tighten them down.
justinator
- Mar 25, 2007
- Maine
So far so good. They have a big surface area and alot of stud support. I think they will be very durable. Everything looks mint but only about 750miles on my sled and 500 on the wifes. As of right now I definitely would buy again.Thoughts on them? Working out on the riots?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks.. I was hoping someone tried them on here..So far so good. They have a big surface area and alot of stud support. I think they will be very durable. Everything looks mint but only about 750miles on my sled and 500 on the wifes. As of right now I definitely would buy again.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have a bunch or the pro-lites if you interested
justinator
- Mar 25, 2007
- Maine
I will re-weigh them but I tried a prolite double with 2 studs vs 2 studstars and 2 studs and there is only a few grams difference. Theres 453 grams in a pound so really no measurable difference at the end of the day but Ill double check the weights to make sure.Thanks.. I was hoping someone tried them on here..
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I'd really like to see these in action as far as durability goes. Similar backer. Nut & backer $10.ea does not include stud.
justinator
- Mar 25, 2007
- Maine
2 studboy studs with prolite doublebacker weighs 73.3 grams and 2 studboy studs with 2 studstars weighs 73.5grams……..so very light setupThanks.. I was hoping someone tried them on here..
- 9K
