Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
1989 Sno Scoot (red)
1989 Sno Scoot (blue)
1995 Vmax 500 (black)
1995 Vmax-4 ST (black)
2003 Rx-1 Mtn (black)
2016 VK Pro
2016 Venture TF
- Happy Valley - Goose Bay
- YOUTUBE
- Mokami
Before I drill out any body panel rivets or remove more than I have to, can anyone tell me if I’ll be able to access the inside nuts of the upper A-arms by just removing the front rectangular/box shaped plastic cover directly underneath in the front?
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Tie rod rubber boots. Gently pry those plastic push pins and you can get to the nuts.
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
Perfect! Thanks for answering.
Mountaintech
X2! Just did it last night.
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
I think you guys must have smaller hands/fingers than I lol.
If I manage to get the bolts out I doubt I’ll be able to get the nuts back on afterwards by accessing only through the steering rod space.
Really wish it were the bottom A-arms I needed to change. Really easy to get at those with the boot off.
I’m going to let the steering rod go from the ski leg, maybe get my fingers in there better that way.
Mountaintech
A deep socket with a piece of paper holding the nut into it, or take airbox off and go from above.
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
Yeah I think I’m going to take the air box off.
Mountaintech
The thin undersized Phazer bushings is just one of the reasons the front end needs upgrading.
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
The power steering on my Venture TF has me totally spoiled now going into my 2nd winter with it. Everything else I ride feels like the steering is duct taped together angle-iron. Stiff, turning, loose/sloppy linkages and darting side to side. Makes me feel guilty that my wife has the harder to control sled than I do.
ATV PRO #11
- Jan 22, 2011
Had my air box off tonight. It’s still a tight squeeze. Kleenex or paper towel to hold but in deep socket your best bet.
Mountaintech
Yeah, this. Works for all four positions.
ATV PRO #11
- Jan 22, 2011
Now that the way to do it!!Yeah, this. Works for all four positions.View attachment 146108
Probably used that 200 times already I bet.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Remove the whole front end, weld nuts to frame. Change oil filter and inspect all steering while it’s off.
- 32K
