03renegade800
I hope somone could make an upgrade to the rear skid that uses the rear skid, maybe new holes for different arms and shocks, the timbersled rear end is 1600, seems like alot, especially when i paid 3800 for my mtn lite with 600 miles.
ak
Re: MTN Tamer rear?
http://www.ty4stroke.com/viewtopic.php?t=62969
Here you go.SideMountAK said:So are they finally making a rear skid for the Phazer. My Son is about to the point where he is bottoming it out all the time. Kids need mods too![]()
ak
03renegade800 said:I hope somone could make an upgrade to the rear skid that uses the rear skid, maybe new holes for different arms and shocks, the timbersled rear end is 1600, seems like alot, especially when i paid 3800 for my mtn lite with 600 miles.
Thats what you get, Is new lightweight arms and new float shocks.
IF you were to buy a set of Ohlins for the rear you would still have a lot of money in to the stock skid and It wouldnt save any weight. There are cheaper options like different springs.
yukonranger
re
Well, it's been a while since any updates on here so I will post some pics.
I decided to build a muffler using a small glasspack out of the butchered stock muffler.
Side by side comparison between the new muffler and the mcx muffler
pipe wrapped and intake together
turbo and new muffler mounted
I also started into my wiring, only to find out that MCX has neglected to update the instructions as the kit changed. Although this was not in any way the fault of Prince George Yamaha, they have found the answers for me and are sending me some new wire harnesses and instruction. Don, Randy, and Harley sp? have been great and gotten this figured out very quickly.
ak
Muffler looks good, was the 08 wiring different then the 07 wiring? Are what was the update in the instructions.
yukonranger
No difference in the miring between 07 mtx and 08 mtx. The wiring differences were between the 3rd ? version of this kit and the version (1st)? that the instructions were written for. updates are a new connector from the efi box and wideband lambda sensor/display, as well, the blue and brown wires on the sled to efi harness are replaced with wires with a connector for the air solenoid. They also included a diagram of the sled to efi connector.
ak
So did you buy the whole display unit?
yukonranger
Yes, the display comes with a wideband lambda sensor as well.
phazerboost
I noticed that you closed off the hole in the front of your tunnel. You might want to keep a real close eye on the temps under your fuel tank. When I closed mine off like that with my header wrapped the metal on the sub frame and heat shields got so hot you couln't touch it. I could also feel a fair bit of heat in the plastic on the fuel tank as well. I ended up removing my block off panel. You might want to install some kind of shield between your exhaust and charge tube so you can keep MAT temps down as much as possible.
ak
^ good eye I dont think you want that front block off plate it will get really hot and possibly cause a fire.
yukonranger
Was your header wrapped? I closed to hole to keep the header wrap dry, I guess I'll have to keep a close eye on the temps. Thanks for the heads up
phazerboost
I closed mine off to protect the header wrap but it got too hot so I removed it. I have since had to wrap the header twice due to it falling off and am just going to send it out to get coated this year. I am going to get the shields around the expansion joints coated as well because the insulation started falling off.
yamahaman
- Jun 2, 2004
i am seeing that to but my wrap is holding up good were did u route that oil return line looks like i need to reroute it is wearing alittle bite
phazerboost
I routed mine on the right side of the charge tube and under the jack shaft and motor mount.
- 6K
