- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Lots of pictures taken. I will try to write up some disassembly instructions similar to what I did last year with the Apex/Attak to help people out.
- Apr 17, 2003
- Menno, SD
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
Side panels removed
go200mph
Great pics man. Did you by any chance look to see if there is enough clearance for a 15" track? Did you notice anything different from the pre production models?
PowerValve-700
Sweet! How much trouble would it be to lower the gauge you think?
ecopter
Thanks for posting. They all look great. On a side note, I'm not too thrilled about the tunnel being left open. I guess only time will tell if it make a snowy mess all over the back, seat and foot rests.
Jon
Jon
fx-treme
- Jan 7, 2005
- 2014 SR VIPER LTX SE
thank you for the pics. now I can drowl over those till my fx arrives.
Yellowknife
WICKED, great pictures, thank you!
- Apr 17, 2003
- Menno, SD
- Menno, SD
That is just some of the pictures I took. There were over 70 in total. Watch the Totallyamaha tech pages for a complete article on getting to certain things on your Phazer!!
go200mph, visually it looks like there is plenty of room for a 15" track, but I didn't actually measure it. I will measure it on Thursday if you want me to. There are a few small things different from the protos, but nothing major. The rear skid transfer stops changed slightly, upper rear idlers are a different material. Any changes were really very small details.
Powervalve-700, just a quick look at it and I believe by drilling & taping two new holes you could lower the gauge pod.
ecopter, they did close in the front half of the tunnel which was open on the proto-type sleds back in February. I imagine with the heat of the exhaust there won't be much of a problem with snow dust and snow build up.
Anyone care to guess on the weight of the machine? Yamaha's estimated dry weight is 485 lbs. I weighed it full of oil, antifreeze, and with the battery charged and installed.
skmon
531lbs?
Thanks for the photos. Making waiting harder.
barnstormer
I'm gonna bet right around 500 even...
