Antewallgren
- Nov 23, 2019
- Sävar
- Sweden
- Yamaha Phazer FX 07
Hello!
I've been thinking of converting my FX to a MTX. Does the MTX bogie fit bolt on into the FX chassis? From what i've read this seems to be the case.
I can get a mtx bogie + track for around $400 in Sweden.
yes it does. i did a 09 rtx to make it an xtx by just using a set of mtx rails, 8 tooth drivers and a new xtx track from yamaha. could not use the stock the 9 tooth drivers as the track would not strech enough to get the suspension in. to make it a true mtx, you need to replace the front shocks and a arms as well as they are shorter than the standard fx.
