BBM
- Oct 6, 2004
It looks like Yamaha was pretty accurate with their HP ratings on the Phazer - 81 HP & 42 lb-ft torque.
Bakemono
Do you know what rpm it produces peak torque at?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
8800 rpm
jp@weknowsnow
it puts out just over 80hp from 10500 to 11700 rpm
LazyBastard
That wide of a power band? Holy smokes. If thats true, then two monkeys and a goat could clutch the thing. Are you sure you don't mean 11500 to 11700?
Bakemono
Are you sure it turns 11,700 rpm? Everthing Ive read says it tops out at 11,250 rpm.
In the '07 Am Snow Buyer's Guide they have a dyno chart for the Phazer and they claim it produces a peak torque of 62.2 ft-lbs @ 6100 rpm (at the clutch).
In fact, there is a whole tech article in that issue about the Genesis 80 FI that is a good read for anyone who is interested. After reading it, Im not at all worried about durability.
p0wd3rp1l0t
LazyBastard said:That wide of a power band? Holy smokes. If thats true, then two monkeys and a goat could clutch the thing.
LMFAO
- Apr 17, 2003
- Menno, SD
- Menno, SD
Like jp said, it makes over 80 hp from 10,500 to 11,700 with peak HP being at 11,100 and peak torque at 8800 rpm.
jp@weknowsnow
thanks srxspec..
Octane-
acording to dynotechjim and his results it tops out at 12200 rpm
Octane-
