BBM
- Oct 6, 2004
It looks like Yamaha was pretty accurate with their HP ratings on the Phazer - 81 HP & 42 lb-ft torque.
Bakemono
- Oct 5, 2004
- Edgerton, WI
- www.myspace.com
Do you know what rpm it produces peak torque at?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
8800 rpm
jp@weknowsnow
- Jul 19, 2006
- colorado mountains
- weknowsnow.com
it puts out just over 80hp from 10500 to 11700 rpm
LazyBastard
That wide of a power band? Holy smokes. If thats true, then two monkeys and a goat could clutch the thing. Are you sure you don't mean 11500 to 11700?
Bakemono
- Oct 5, 2004
- Edgerton, WI
- www.myspace.com
Are you sure it turns 11,700 rpm? Everthing Ive read says it tops out at 11,250 rpm.
In the '07 Am Snow Buyer's Guide they have a dyno chart for the Phazer and they claim it produces a peak torque of 62.2 ft-lbs @ 6100 rpm (at the clutch).
In fact, there is a whole tech article in that issue about the Genesis 80 FI that is a good read for anyone who is interested. After reading it, Im not at all worried about durability.
p0wd3rp1l0t
LazyBastard said:That wide of a power band? Holy smokes. If thats true, then two monkeys and a goat could clutch the thing.
LMFAO
- Apr 17, 2003
- Menno, SD
- Menno, SD
Like jp said, it makes over 80 hp from 10,500 to 11,700 with peak HP being at 11,100 and peak torque at 8800 rpm.
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
thanks srxspec..
Octane-
acording to dynotechjim and his results it tops out at 12200 rpm
Octane-
- 6K
- 23K
- 14K
