kodak
hi i'm new to the forum but while googling phazer mods clips from this forum kept coming up so i decided to join . its close to christmas and all i want is a liittle more performance from my phazer mtx witrhout the cost of turbo i see some of you have exhausts, fuel accelerators, clutch kits mainly ulmer when i checked out online it mentioned every model except mtx my phaz is 08 can you tell me some stuff you've done and how i can find it. please use terms a rookie like me could understand. thanks
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
excell exhaust, ulmer clutch kit, cold air pods, and a pc3 or pc5.... prob right around a $800 to a grand for everything, should add 12-15hp..
yzman
Aaen exhaust , 12 lbs lighter/9 hp increase and 11 hp with an enriched fuel cure (Witch can be done by CO adjustment..Free..) . Is another alternative to the excell exhaust .
kodak
thanks for the mod tips guys I'm alreaDY ALL OVER THE ulmer clutching once i get the clutch installed is there any adjustments or is it a once installed just ride. and if i throw an exhaust on is there anything i'll need to recalibrate. sorry for all the questions but it 's not everyday you get to ask guys who know what there doing and have already tested the stuff
yukonranger
I may be wrong but I'm pretty sure the CO only adjusts the low end ie the equivalent of a 2 smokes idle jet.
yzman
Nothing , you can throw it on and gokodak said:thanks for the mod tips guys I'm alreaDY ALL OVER THE ulmer clutching once i get the clutch installed is there any adjustments or is it a once installed just ride. and if i throw an exhaust on is there anything i'll need to recalibrate. sorry for all the questions but it 's not everyday you get to ask guys who know what there doing and have already tested the stuff
yzman
It adjusts the whole range , low , mid and high . I have an o2 sensor this season , ill put it to the testyukonranger said:I may be wrong but I'm pretty sure the CO only adjusts the low end ie the equivalent of a 2 smokes idle jet.
phazerfanatic
what is a co adjustment and how do you do it?
I have the ulmer clutch kit ultra q and air box mod but still looking for more.
kodak
I have no idea what a co adjustment is but where did you get your mods and how much for each be specific because i'm looking for the same gear let me know if it was worth it. you can look at yzmen's profile and ask him a private message about what you want to know. he seems to know his stuff.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
CO Adjustment can be found in this thread.-------> http://www.ty4stroke.com/viewtopic.php?t=41865
kodak
Thanks for the info great help
- 71K
- 46K
