phazer mtx 2007 supercharge build
msrx700
quebec
phazer mpi supercharge
my 2 phazer mtx 2007....
both in work
mpi supercharge kit
stock engine base freshly clean
intake job
exhaust job
head before milling
head after milling with new valve and 5 angle race cut valve
right cylinder from stock engine with broke rod (many over speed)
right cylinder from another stock engine with lot of milage (maybe phazer mp)
need remove piston for check why cylinder chrome burn
Wow exact same pattern.Should be able to figure out your rod failure once you get the intact one apart.
rear view
side view
charger and oil tank
thermostat housing with sensor
SLP extension on charlenger 151 x 2.3"
with 4th wheels kit
