519yamahammer
- Sep 6, 2010
- Elmira
- 2008 Yamaha Vector GT
Just got a 2008 Phazer GT this season, and am having a problem of the reverse engaging when the dashboard button is pressed. I have to lift up on the rear skid, in order for the reverse to couple, and then once again for it to engage back into the forward state. I know a lot has been written on this forum about the issue, but as far as the washer update is concerned, from Yamaha, where should I look for, to see if this update has in fact been done. Thanks in advance.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Look for the newer belt. Part number starts with GK. The original one starts with GS.
One thing you can check is the chain tension adjustment. I found it helped if it was on the loose side. Adjust it to just when you feel it contacting the chain and back off 1/4 turn.
My MP has been a real biatch lately since I changed to the newer belt. I didn't add a shim since it was too low in the sheaves. In fact, I removed one to bring it up to where is should be. I might go back to an old belt to see if that helps.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Usually a quick little "hop" while standing gets mine to go. Loose chain works good too.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Try turning key on with the throttle cracked and then release throttle and start. It's been working on the wife's.
